Axel seal leaking
Hi there. Who had an experience in changing axel seal of gear box, driver side. We already change 3 seals but leaking still have place. Maybe is there any features? Cx5 2014
Make sure you are purchasing the correct seals.
After market ones don't always work.
How To Replace Mazda Axle Seal/2013 Mazda CX-5 Axle Seal Removal And Replacement - YouTube
With a 2014 it's possible backlash could be an issue due to wear.
There are bunch of different shims for adjusting that, but I have no idea what the specs are.
It can also be your axle shaft carrier bearing or even the axle itself.
You can mess around with all that but probably be cheaper to take it to an authorized dealer of Mazda mechanic.
If you have one handy anyway but I suspect being in the Ukraine right now that's likely not top on your list.
