AM/FM radio
Old Jul 8, 2025 | 09:29 PM
orion's Avatar
Default AM/FM radio
We only listen to broadcast radio in our car. When we had our 2006 Mazda 6 when travelling away from home, we could temporary install the six strongest radio signals on each of the three sections, AM. FM1. FM2. We could then pick a strong signal from a suitable station. On our 2024 CX5, we don't have this feature Activating 'Station List' seems to show ALL the stations it detects in AM and FM and sows the MANY it found in order of frequency and not of signal strength! Is there a way to do what we did before on a much older vehicle!
Old Jul 9, 2025 | 06:21 AM
You can manually add the stations found that you like to your "favorites", or you can manually search for them and add them to your "favorites".
Your owner's manual should show you how to do this or you can find some online videos that will.
Old Jul 13, 2025 | 12:45 AM
orion's Avatar
Yes thanks, We thought that might be the only way to do it. We liked it on the 6 as we could instantly get the six strongest stations when driving across the country and in some places in the middle of both there might only be a few stations we could pick up, and we would repeat it every few hours.
Old Jul 13, 2025 | 01:07 PM
jonnyuk's Avatar
Yes I have added all "The best FM stations" to my favourites, the only problem I find its that if you travel out of range, it does not auto update. DAB for example is great if you are sitting still, but the moment you leave the area, it doesn't automatically find the signal again, as a result it constantly loses signal!- Although It could just be my car???
Old Jul 13, 2025 | 07:16 PM
orion's Avatar
Yes, it's a pity they removed this feature!
Old Jul 14, 2025 | 04:48 AM
hsdejong's Avatar
MZD Connect (the latest infotainment system)
https://www.mazdausa.com/static/manu.../34020300.html
Station List
The radio station list is displayed where you can select the radio station you want to listen to.
The genre of the radio station displayed in the list can be selected and the list can be updated depending on the region and specifications.
(If Option is available and the genre can be selected)
A list can be displayed by narrowing down to genres such as News or Rock M.
(If Option is available and “Update List” can be selected)
The list picks up the 10 stations with the strongest radio waves and they are displayed. When Update List is selected, the Station List can be updated at an arbitrary timing.
(With Radio Data System (RDS)
You can enable/disable the “Traffic Announcement Settings”, “Alternative Frequency Settings”, or “Region Lock Settings”.
Old Jul 14, 2025 | 08:07 AM
Point37's Avatar
the mazda am/fm radio interface is awful...the most unintuitive design of any car i've ever owned
Old Jul 14, 2025 | 09:51 AM
orion's Avatar
Thanks HS, I'll see if we have those options , I'm thinking that maybe we do not.
Dunnsm98
Jul 15, 2025 10:33 AM
Ferb
Nov 5, 2021 07:36 AM
Larry L
May 5, 2017 02:47 PM
mazdamike58
Mar 20, 2010 06:41 AM
Lovemytribute
May 13, 2007 01:02 PM
