2022 CX-5 2-3 shifting issue
How can you say it is not normal when your Service shop has not found the cause yet? If you are experienced with the full operation of the Skyactiv Transmision and the TCM then why are you not telling the shop what the cause is? How did you fully determine it was the transmission? How about waiting until you or the service shop actually finds if there is a problem and the component that is the concern instead of second guessing even your shop at this early stage of diagnostics?
ASE
ASE
the tech did say that its not right, it hasn't thrown a code yet, that's the issue of the diagnosis . I have driven every cx-5 model year since 2013 this is the first time with this issue. I have driven the 2023-2024 models and the ones I've driven don't do it, I have video of the tachometer jumping up in the rpms as it shifts. They have a ticket into Mazda Canada, but no response yet. Not sure where you read on my reply that I said it was transmission, I didn't mention what component. You may have some of your response confused with the original poster.
So how many miles on your Mazda dn at what miles was the transmission pan oil and filter serviced?
There's a TSB for the rough shift issue. Applies to 2018-2025 non-turbo cx-5 Skyactiv-G A/T CX-5s with vin lower than JM3KF******565864 (pre aug 27, 2024 production).
Bulletin says shift shock when shifting from 2-3rd gear when engine is cold, caused by "improper TCM control logic", there's a software update to reprogram the TCM for this issue. Ask the service department to look at TSB# 05-006/24, it was recently issued in October of this year.
This is not "normal operation" regardless of what the "experts" on this forum tell you. I have a 2023 CX5 and have the same issues as the OP. Vehicle has been to the dealer 3 times and they acknowledge the defect. trans relearn did not work on all occasions. Ticket is currently open with Mazda and I have a CX50 loaner (no issue with trans). I expect the software update to be performed. TSB attached.
This gentleman had a new transmission installed by Mazda under warranty and has documented his experience.
New member is duplicating the same response on several threads see his profile
Please note that this thread is several months old since last response prior the new members. Mar 7, 2024 | 07:57 AM
This gentleman had a new transmission installed by Mazda under warranty and has documented his experience. https://www.youtube.com/watch?v=PrdhwQ5Sfv4&t=253s
the you tube is full of missing information none factual information and bad unverified or fact check info based on un- verified sources of the same . For a smart guy you should seen that to some degree when you viewed it and a few more videos or at least one other by that person. In short one of the worst videos to use for any supporting information. The author of the video also was careful not to show all the details on the service write up and also who actually paid in the end Mazda or the dealership. Because I know and it was not all Mazda corp USA based on what was said in the video. Ya see there is only a couple of Mazda dealers close to his home and it would be easy to do an inquiry for service info , if you were connect to any Mazda dealer ships part or service department.
my guess is he was smart enough to know that making a video of that caliper and identifying the dealership could have possibly legal ramifications of sorts.
So if you are a simple owner or very light DIY I CLEARLY understand the thought process in liking the video .
I have my vehicle back after the the TCM was updated with the latest software by the dealership. The TCM update fixed the issue as per the TSB I posted. This was covered under warranty.
I just called my dealer and they verified that my 23 CX-5 falls within the vin number window and willing to schedule an apt to reprogram my transmixer under warranty. Wow, no arguments, or hassle. We shall see, haha
