(2015) Question about ATF change and auto AC function
Old Apr 5, 2021 | 09:29 AM
jmejiaa's Avatar
Default (2015) Question about ATF change and auto AC function
Hi All, I've been browsing the forum and had some questions about my recently purchased 2015 Grand touring.
1. I've seen a lot of comments about changing the ATF and not trusting the "lifetime fluid". Most of these suggest doing it around 40k miles. I purchased the car with 77k and it hasn't ever had this done. Is it too late to do it at this point? I've read that doing it too late might actually make things worse.
2. I love the climate control and it's the first car I own where it seems to work great. I notice it keeps the AC on by default. Does this mean the compressor is always working or is the car smart enough to turn it on/off as needed? I'm not sure if I should just leave it on all the time and turn it on/off myself.
Thanks everyone!
Old Apr 5, 2021 | 09:50 AM
Conrad 16.5's Avatar
In my opinion it's not too late to change the ATF. The sooner the better.
It's my understanding that the AC compressor will cycle on and off as needed. That said, if I'm not in need of cooling but I do need some heat and/or ventilation, I manually turn off the compressor/AC switch. It remembers my setting on the next start up.
Old Apr 5, 2021 | 04:31 PM
Dennis Wendt's Avatar
Just my opinion but two changes for your transmission isn't a bad idea either.
The older transmissions used by Mazda were not the best.
So, flush, drive for a few hundred miles and then flush again. that gets most of any
nasty fluid out.
My 2¢
Old Apr 5, 2021 | 07:14 PM
CarpeDiem's Avatar
Old Apr 5, 2021 | 09:39 PM
LOL ....
PM if you want some personal help. What I can provide for you for information you can decide to post it or not.
Sometimes I don't care to cross swords with people that really have no real experience answering technical questions on forums and would rather call me names or challenge what I post instead of realizing this is what I have done professionally for over 34 decade of my life. LOL
Old Apr 6, 2021 | 05:12 AM
schmieg's Avatar
LOL ....
34 decades?
Old Apr 6, 2021 | 07:00 AM
9O.,NQi&'s Avatar
My understanding is that the A/C is on as you describe as a method to keep excessive humidity out of the air, i.e when the defroster is on since the cooling cycle by nature removes humidity. I believe in most cars the A/C evaporator coil is ahead of the heat coil in the unit so the air can be cooled and dehumidified and then heated to the desired temperature if necessary. My suggestion would be to just leave it on, The compressor has an electric clutch on it that will engage when the A/C is needed. the restof the time it is not putting any load on the engine.
Old Apr 6, 2021 | 07:49 AM
LOL ....
340 years? Wow!!!! You really do have some experience don't ya? Sorry, I couldn't resist.
I for one would like to hear your opinion on the subject and I promise not to call you any names or to challenge you on this.
Old Apr 6, 2021 | 09:41 AM
Originally Posted by schmieg
34 decades?
LOL I think you knew what I meant
3 decades
Funny you can always tell the old timers on automotive based forums, they are generally the ones that find mistakes in sentence structure ,grammar, spelling and obvious typos!
Old Apr 6, 2021 | 09:49 AM
Conrad I have posted about this a few times on this forum and it ALWAYS gets argued and debated from people that have no practical service shop experience on the subject. I invested 4 thousand dollars 2 years ago to replace an ageing Transmission service fluid machine for a very nice one that I have performed personally at lest a dozen or more complete transmission fluid replacements and a few had the fluid first analyzed by Blackstone Lab before recommending the service work.
You can look into my past response if you are truly interested regarding my comments.
BLACKSTONE LABS
https://www.blackstone-labs.com/Transmission
https://www.blackstone-labs.com/engi.../transmission/
Automatic transmissions ask a lot of the oil. Not only does the oil lubricate and clean internal parts, but it also functions as a hydraulic oil to operate various components.
Transmission oil can be contaminated with metals, solids, and moisture, and those contaminants need to be removed before they cause problems. Conversely, a test of your transmission fluid may reveal that it’s still in great condition, and you don’t need to change it as often as you thought.
There’s no easier way of knowing what’s going on in the system than oil analysis. We can tell you if the oil needs to be changed, if it’s contaminated, or if there are any problems at hand. Request your free kit today and make sure your drive train is wearing as it should!
