2015 mazda cx-5 HID TO LED headlight conversion
I have a friend that had something fly up and hit her 2015 mazda cx-5 grand touring car and damage the drivers side HID headlamp assembly.. with her budget she was told that she could replace both headlamps with the LED headlamps cheaper than she could replace the one HID and that there were a direct fit plug and play replacement... so i went to install them for her and the plugs are completley different.. i looked further down the harness to see if a section of harness was removable, but didnt see anything.. So my question is, is there a conversion harness to do the swap? thanks for the help
hello,did you get answers on this?cause i am in the same boat,i need passenger HID headlight,but considering of puting in both LED headlight,i dont care about harness that much,cause i can make it fit,but will everything work as it should,some ECU faults or similar,any help would be great
