V8 swap...B3000 Pick-up truck.
Thinkking about swapping out motor to a Chevy 400ci /6.6 liter.
Anybody have any info. that might be good? |
RE: V8 swap...B3000 Pick-up truck.
Come on guys where are the V8 Guru's
yah is that the small block if so use a 1974 chevy nova radiator fits perfect build mounts. then pretty much everything else as far as mounts built them all to the specs i needed. have any specific questions feel free to ask. also what year is the truck
It's a 94, I wonder if there would be enough room and what kinda trouble's I would run into. Also planing on changing out the drive line, TH350 and a 9inch rear end.
mine had plenty of room for the t350 tranny and i will also be putting a 9 inch rearend when i get the time i have a gm 12 bolt car rear end. yah you shouldnt have many problems measure twice cut once. well ttyl
i want to do a 383 stroker in a little pick up with a T400 matched up. got the motor, just need to rebuild it and find a truck to put it in. my dad has an old supercharger that i want to talk him out of.
