-   Mazda BT 50 & Pickup Trucks (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/)
-   -   Turn fan speed up, A/C compressor shuts off! (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/turn-fan-speed-up-c-compressor-shuts-off-14045/)
chiefsfam Apr 19, 2008 10:43 PM
My teenage son has a 1987 Mazda B2000 pickup. It recently developed a problem with the A/C. Starting at the fan speed in the off position and the A/C dash buton pushed "On": turn the fan speed up 1 notch. A/C compressor turns on, but fan doesn't run. Turn fan speed up to the next notch, AC compressor still on, still no fan. Turn fan speed up one more notch, fan comes on but A/C compressor turns OFF! Turn up one more notch (high speed), fan runs but A/C is still off. I replaced thefan speed controller switch (the switch attached to the dash knob)but it still does the exact same thing...so I'm assuming the problem isn't in fan speed switch. What else could make the fan not run on 2 notches, and the A/C not run on 2 notches??? Any help anyone could give would be GREATLY appreciated! Thanks.
Cusser Apr 20, 2008 11:41 AM
RE: Turn fan speed up, A/C compressor shuts off!
There's a resistor pack under the dash, attached to the evaporator box.
chiefsfam Apr 20, 2008 05:15 PM
Thanks. I'd have never guessed that one. I'll pick one up tomorrow!
toddluck Apr 21, 2008 05:36 AM
also sounds like freaon might be low
Cusser Apr 21, 2008 01:50 PM
Refrigerant amount will not affect blower fan off/on/speeds.
dansel Jul 16, 2009 01:32 PM
I have a similar problem. I have a 2002 Protege5. My problem is as follows:
AC Switch on, Fan setting 1: AC and fan work
AC switch on, Fan setting 2: Fan works, AC does not.
AC switch on, Fan setting 3: Fan works, AC does not.
AC switch on, Fan setting 4: AC and fan work.
The AC used to work on fan setting 2, though it would take several minutes of the car running before the AC would start working. The problem has gotten worse over time. Sometimes I can make the AC and fan work concurrently by carefully turning the fan knob to a spot between settings (ie, between 2 and 3).
After taking apart the control unit and re-connecting the switches to the AC and fan switches the problem was remedied... for about a day and a half.
electric Jul 22, 2009 10:57 AM
I have a 1992 b2200 carb.If I have my fan in position 1 the fan and a/c work.If I move the switch to 2,3.ect.. the fan keeps running but the compressor turns off.Sound like we all have the same problem.
Has anyone found the answer yet?
THANKS
JOEY
Cusser Jul 22, 2009 10:31 PM
I posted this above.
electric Jul 23, 2009 08:13 AM
Are you talking about the blower motor resistor?It is the only resistor I can find on a parts list.
http://www.autozone.com/autozone/cat...hText=resistor
Cusser Jul 23, 2009 10:03 PM
Yep. From others here I learned that these go bad sometimes. I'm still on my original.
