trans swap
I have a 90 mazda 2600i with an automatic trans and have had nothing but problems with the tranny. I want to convert to a manual tranny and would like to know if this is possible and what is involved?
Here is a link of someone else doing the swap:
http://www.mazdatruckin.com/vBulleti...4811#post34811 You will need the manual tranny, pedal assembly, clutch master, clutch slave, clutch lines, flywheel, clutch, driveshaft, and you'll have to modify the frame to use a carrier bearing. There will also need to be some slight electrical modifications. |
