Speedo Drive Gear
Anyone know if you can switch/ need to switch the speedo drive gear when you have put a motor & transmission from an 86 B2000 to a 89 B2200?
The speedo is definetly out of whack and its not the tire size or speedo cable as I have played with those two... thought it might be the speedo drive gear as it may match the original rear differental.... Thoughts...? |
RE: Speedo Drive Gear
ie could there be different gear ratios for the 86 and 89 transmissions?
