-   Mazda BT 50 & Pickup Trucks (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/)
-   -   sending unit out line cracked, leaking gas! what tanks work with 2600i??? (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/sending-unit-out-line-cracked-leaking-gas-what-tanks-work-2600i-18239/)
lil' lucifer Apr 5, 2009 08:07 PM
Got a problem.....I have a 1991 mazda 2600i 4x4, reg. cab long box......
My gas tank was leaking bad when it was running, so I pulled it to find out that the metal out line that's attached to the top of the fuel sending unit was cracked.
So I began to pull the sending unit out and all the little screws are stripped. But I managed to get it out but now the tank is garbage(cause where you bolt unit to is fudged)
So now I need a sending unit for the the tank and a new tank....
what tanks will work on my truck?
I heard that as long as it was injected(2200i or 2600i) it did matter if it was 2wd or 4wd, BUT I needed to find one that was a long box, regular cab......IS THIS TRUE??????
thanks for the help
tyler
lil' lucifer Apr 6, 2009 10:59 AM
nobody know anything about this???
:confused:
mazdab2600 Apr 6, 2009 11:53 AM
the tank has to be for your model.it bolts on to the cross supports in the frame
spectra premium lists mz6c for reg/long/efi.
new tank comes with the screws and seal
as for the sending unit.dealer unit(new) or rebuild it yourself.
as i did.
drill out the old fuel line and solder in new steel line.
