| 90-B2200 |
Mar 2, 2023 10:28 PM |
I have that same Haynes manual. I’ve done this rocker shaft removal and install more than once before this time. It sealed up good the first time but for some reason it didn’t the second time.
I remember being skeptical about putting the sealer too close to the cam bearing surface. I didn’t want the sealer spooging onto the cam bearing surface. This time I just put it in the entire shaded area as suggested in the manual. I did have the mating surfaces spotless clean and dry. However I took a clean rag and soaked a corner with wd40 and rubbed it on the cam bearing surface. My goal is that when the sealer hits the bearing surface the WD40 would repel it from sticking where it should not be. I also but a small dab of assembly lube in the top of the cam bearing surface. Just enough so when the cam rotates it will distribute the lube. At the same time, the small dabble on top won’t smear all down into the flange sealer and prevent it from setting properly. After setting it all together like this I have not rotated it yet. I want that sealer to set up good before it starts sloshing oil all around in there.
