Need Help turn lights '88 B2200
Old Jul 10, 2007 | 08:18 PM
Daryl's Avatar
Default Need Help turn lights '88 B2200
I could use some help. I have a 1988 B2200 Pickup and my turn signal lights have stopped working. All other lights work fine. I checked the fuses and they are all good. I have checked all of my bulbs and replaced the turn signal flasher however they are all still dead. If you turn the signal lever, nothing happens, no noise, no lights, no left, no right, nonothing. I have checked all the wires to the lights and they all appear to be intact.
Any ideas? Please!
Old Jul 11, 2007 | 12:10 AM
Cusser's Avatar
Default RE: Need Help turn lights '88 B2200
Are you getting 12 volts positive (or flashing) to the turn signals themselves? If not, are you getting 12 volts positive to the flasher unit, and out the flasher unit as flashes? Use a voltmeter or a test light. Obviously, your flasher unit is not "clicking" on and off like it should, you should hear it. The turn signal switch merely directs the current flow to either left or right.
naraku137
May 30, 2009 12:08 PM
Josh701
Aug 20, 2008 10:25 PM
vetteboy777
Oct 20, 2007 07:42 AM
xtrigger
Aug 10, 2006 10:21 AM
mazdadam
Apr 15, 2006 03:49 PM
