greystang |
11-01-2012 07:11 PM |
Mazda b2300 starting problems
Hi All. I recently acquired a 1995 mazda b2300 with the 4 cyl. manual transmission setup. the truck seems to run fine for the most part, with the only exception being that after you drive it for a while and shut it off, it won't start again until you let it set for a while. After it sets for 15-20 minutes it fires right up again. I've replaced the fuel filter and the fuel inlet hose (outside was cracked badly). While I had the bed off, I pulled the fuel pump and checked the tank which turned out to be extremely clean. After replacing the hose and filter, it gave no problems for about a week, but is now starting to act up again with the same problem. Anyone have any ideas where I should turn my investigation? Seems like a fuel problem, but not sure. Any thoughts would be much appreciated. Thanks.
P.S. Side note: The dome light didn't have a light in it so I got one for it and plugged it in. Light won't shut off for some reason (probably why someone had pulled the bulb out). Not much of a wiring guy so not sure how to tackle that one.
