Leaking front seal on B2000
Old Feb 1, 2016 | 09:08 PM
Mr_Leffe's Avatar
Default Leaking front seal on B2000
Is it a big or small job to replace the front seal on a B2000.
Some days it leaves a flood on the pavement, others a megre drip.
Old Feb 3, 2016 | 10:07 PM
Cusser's Avatar
There's a camshaft seal and a crankshaft seal up front. They are the same part number. You need to know how to change a B2000 timing belt - if you know that, not too tough.
The big center bolt on the crankshaft needs to come off for the crankshaft seal (and get properly re-torqued), a big 21mm socket.
Old Sep 21, 2016 | 07:19 PM
oldmazdagal's Avatar
It kind of depends on the year but on my 1987 the entire front end had to come off so I did the timing belt at the same time. You may want to consider replacing the rear main if you are already in there as a new seal may cause pressure on an old one nearby(part of the same system).
Old Sep 22, 2016 | 08:17 AM
Mr_Leffe's Avatar
Yes the front does have to be taken off. Rear seal sounds like a HUGE amount of work also.. Yes / No?
Old Sep 22, 2016 | 09:39 AM
Cusser's Avatar
For rear seal, engine or transmission must be removed. Leak at rear can also be oil dripping from mechanical fuel pump, valve cover gasket, cam plug.
Front seals: a little more work than doing a timing belt/water pump. Be sure to tighten that big 21mm crankshaft bolt to the correct torque though, so you don't ruin the crankshaft keyway (that bolt does not need to be removed for just a timing belt or water pump change).
B2200 & B2000 Timing Belt - Mazdatruckin.com
B2200/B2000 Timing Check
bluelinepwr
Jun 25, 2014 02:51 PM
juju14
Jun 11, 2014 09:01 PM
jhppc14
Dec 13, 2011 02:56 PM
Mr. peepers
Mar 16, 2007 01:21 AM
picky
Nov 13, 2006 09:20 PM
