intakes
will the carbed intake for a 2.2 fit a 2.6? and does any one here make plates so i can bolt on a holley?
RE: intakes
No and I'm guessing no to the second one too.
I have thought about making one up. It'd be of steel though, I can't weld aluminum. I want to make a tubular intake that will directly accept the Holley 2bbl carbs. You can get those in 350cfm and 500cfm, either one would be plenty for anything on a B2600. Actually, the 350cfm would probably be more than enough for 99% of people. |
RE: intakes
well im fixing to put a short block in mine unfortunatly some one pulled out the 2.2 and dropped in a 2.0 so i have no core if i want to put back the original 2.2 therefore i'll be dropping another 2.0 in my 93 b2200. oh well now for another q. does the 2.0 head bolt on the 2.2 correctly and if so how much of a compression gain does it give?
Flores |
