The Intake Air Thermo Sensor?
Man i have looked everywhere for the one i need, cant find one, does anyone know where i can find one, a site, or car place.....?:( AWWW.. and my truck want crank when its cold, turns over fine, but want stay running? what could that be you reken? And it want crank when i jump in and turn the key, i have to count to like 7 before i turn the key, before it will crank up and run, but when its cold, it want even do that? any ideas what could be causing my problems...? thaks
RE: The Intake Air Thermo Sensor?
Did you need the early production part or the later production? You can find either one used at wrecking yard. If looking for new then both are available from one of our sponsors, mazdapartsonline. Click on the sponsors link at top of forum page to find them. They are also available from Mazda although they are $15-20 more. The early production is a part #N326-18-845 and can be ordered at any dealer. The later production is part #F2G8-18-845A. I show one is available at Blackmon Mazda in Tupelo which should be fairly close to you. There # is 662-844-1383.
Not sure I followed all about the truck not starting and cranking at different times. You have to wait 7 seconds with key on before it will even crank over? Do you hear a click from starter solenoid when this happens and do dash lights all come on normally? |
