Fog lamps won't turn on or the signal on the dashboard.
Mazda B3000 V6 pickup.
She went to the shop, came back, and the fog lights are missing. They don't shine when I flash them (pull the lever), turn them on (push the lever), and neither does the fog lamp signal on the dashboard. Don't have a fuse box diagram so don't know what to do. Thanks. |
Take it back to the shop - it wasn't malfunctioning when you take it in, likely related to what they did. Remember your truck is essentially a Ford Ranger.
Originally Posted by Cusser
(Post 154308)
Most fuse boxes have the fuses listed either on the outside or inside of the lid. Also alot of vehicles have more than 1 fuse-box.
(Post 154310)
Owners Manual?
A fuse was missing from the fuse box.
I got a diagram for a 2001 Mazda B3000 SE and the fuse for "headlamps, daytime running lamps module, instrument cluster, fog lamp relay" was missing. I don't understand why only the fog lamps (the high beam lights I mean, don't know if they are synonymous) stopped working and not the "headlamps"... This shall remain a mystery to me. |
Originally Posted by Cool_Ichi
(Post 154306)
(Post 154321)
I got a diagram for a 2001 Mazda B3000 SE and the fuse for "headlamps, daytime running lamps module, instrument cluster, fog lamp relay" was missing. I don't understand why only the fog lamps (the high beam lights I mean, don't know if they are synonymous) stopped working and not the "headlamps"... This shall remain a mystery to me. But if you did have fog lights, these normally go out when hi beams are on. Pics below are from my 2006 Mazda 6. http://i1049.photobucket.com/albums/...ge/HiBeamA.jpg http://i1049.photobucket.com/albums/...wBeamFogsB.jpg |
(Post 154323)
I knew this thread was confusing. Fog Lights ARE NOT hi beams! You were describing hi beams!
On most cars there will be different fuses for low beam & high beam, also some cars will have separate fuses for LHS & RHS.
