eI have a 92 B2600i 4x4 5spd....I did the compression test check it out
I have a 92 B2600i 4x4 5spd....I did the compression test and regapped the plugs (.041 and trucks RUNS much better).....
my engine has 317 000kms and it pumped out 155PSI each (4cyl) and i have looked up and 140PSI is min 180PSI MAX and with 317 000 i think 155 is very good......am i correct?? thx |
RE: eI have a 92 B2600i 4x4 5spd....I did the compression test check it out
would you poeple think that these numbers are a good sign that the engine is very good? i think so....any input is welcome
That sounds good. If they are even compression and within 10% of each other.
they are all 155PSI + or - 1-2PSI......
Yep. Sounds good...especially for a high mileage engine:D
| All times are GMT -5. The time now is 03:15 AM. |
