Doing an engine swap
I'm doing an engine swap on my 89 b2200 single cab long bed 5 speed stick. Need to know what other 4 cylinder engines will fit with out haveing to change mounts or anything i wanna go with one with a carb don't like the fuel injected. anyone know what i could use??
As far as direct fit, the same engine is all that I can say. If you want to stay carbed and do something cool, a 12a rotary swap isn't too hard. Just go to atkins rotary and he will build you the mounts. Use the trans from the rotary and have a driveshaft built.
