-   Mazda BT 50 & Pickup Trucks (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/)
-   -   dash lights and parking lights not working (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/dash-lights-parking-lights-not-working-18544/)
jpaschal21 May 3, 2009 12:54 AM
My dashlights and parking lights aint workin on my 88b2200 if anybody knows how to fix please let me know
Cusser May 6, 2009 12:29 AM
Do the taillights work? They should be on same circuit as parking lights. Have you tried jumping or turning the rotary switch on the dash to see if that makes the dash lights work?
sdinant21 Jun 16, 2009 11:35 PM
i have 97 protege park lights and cluster light went out replaced fuse for park lights they worked for a little while then it blew again, all warning lights work in cluster all work except for the back lights to see speedometer at night is that a bad switch????
hixx Jun 17, 2009 07:59 AM
Did you install a new radio recently?
sdinant21 Jun 17, 2009 09:39 AM
no new radio only thing new installed before this happened was a battery by autozone
sdinant21 Jun 17, 2009 06:56 PM
ok after searching all around i took dash apart at the relay it has 4 wires on it 2 power in, 1 to the switch, last power out. the power out had a break in it causing the fuse to blow and melting the coating on that wire which now has to be replaced thanks for any help previously and hopefully this can help others
