Broke frt shock mount bolt
On my 94 B4000 4wd, I was replacing my front shocks and the bottom bolt shock mount twisted off, the one on the bottom. Can that bolt be taken out and replaced? I can't tell whether it is welded in or not? Anyone have any info on that or what I should do?
THanks. |
RE: Broke frt shock mount bolt
Does not show to be a replaceable part in the Mazda parts catalog. Can only get with the tension arm that the stud attaches too. You may be able to improvise something but probably no worth the trouble as the OE replacement arm is only $68. If you decide to go with used part make sure it is from a 94. The 95-97 shows to be a different part number from 94 MY. 94 OE part number is a ZZM1-34-223.
| All times are GMT -5. The time now is 04:07 AM. |
