-   Mazda BT 50 & Pickup Trucks (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/)
-   -   brake check valve? (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/brake-check-valve-36196/)
dragonmp5 Nov 24, 2015 01:02 PM
brake check valve?
93 b2600 2wd 5spd. I have come across this reference to a check valve in the braking system but cannot find anything except for emissions stuff. Can anyone clarify this for me? I have been wondering about this as a possible cause for losing pressure when pressing brake petal for booster testing. It builds up pressure then slowly releases it. While driving it feels a little soft. I have not bled brakes but plan on doing that tomorrow.
grim_reaper Nov 26, 2015 06:06 AM
There will be a proportioning valve that splits the pressure front to rear. There may also be load proportioning valve on the rear axle to adjust brake bias from no weight to fully loaded tray.
A full clean & adjustment of the rear brake shoes & a full brake fluid flush is in order.
Cusser Nov 26, 2015 08:31 AM
There is a check valve inside the short curved vacuum hose that leads right into the brake power booster. Is that what you mean?
dragonmp5 Nov 27, 2015 01:39 AM
I wasn't aware there was one in the hose. How do i test it?
Cusser Nov 28, 2015 08:36 AM
Try to blow air through it; should only go in one direction. There is an arrow on the outside of the hose and states "to engine".
I haven't had one of these check valves go bad myself, but I've owned my '88 B2200 21 years now and have replaced the power brake booster exactly once. I have replaced the brake master cylinder several times over that time, and the calipers once each. I don't remember doing either rear wheel cylinder.
dragonmp5 Nov 28, 2015 07:12 PM
I'll check it out as soon as everything defrosts. We just had a small winter ice storm blow thru and everything is frozen till at least monday.
