blue morning
every morning im seeing blue! lol 92 b22 and first morning cold start up is nothing but a puff of blue smoke. now clearly its oil, i did an oil change and threw in some lucus in with some 10w30 (im canadain so iv got some cold mornings!) is there anything i should be watching for other then my oil levels?
RE: blue morning
sounds like your valve seals are leaking. just watch your oil level and fix the seals when you get time because it will only get worse.
RE: blue morning
well so far so good on the lucas oil stuff. i started er up this morning and there was only a little puff of smoke rather then a huge one. but this truck has been nothing but issues since i got it so im just gonna drive it till i can afford something else.
i apreciate the advise though, thank you |
RE: blue morning
same here, i put 10/30 in it when i bought the truck but it burned that up real quick so now i use 10/40 and some of that "no smoke" stuff and it works good. i've also had a lot of problems with the truck and am still trying to pass smog after 3 months of working on it.
RE: blue morning
ya, aparently that was just a short lapse in the burning. its still reduced but i dont know how much longer im gonna put up with this. i havent even tried the emissions test yet.
RE: blue morning
my mazda has 390,000 smokes like crazy in the morning then clears right up......i deal with it cause it runs dayum good
RE: blue morning
yup, my truck run fine but the smog numbers are off the charts.
RE: blue morning
it goes in for the emissions testing with in the next day or two. *fingers crossed* (not holding my breath mind you)
