backfires on decelleration
Old Apr 15, 2007 | 12:16 PM
chickenandpickles's Avatar
Default backfires on decelleration
my 91 2600i likes to backfire when decellerating...i need help diagnosing this issue so i don't have to take it into a shop...keep the suggestions coming...
the only issues i have with the truck is that it uses oil a bit, prolly due to valve seals cause it smokes on startup...
Old Apr 15, 2007 | 12:50 PM
eflores's Avatar
Default RE: backfires on decelleration
vacume leaks can cause this and burnt valves too....if you had a carb it would be very easy to diagnose....do you still have cats on it?
Old Apr 15, 2007 | 07:33 PM
i had the cat cut out..still let's out a backfire sometimes...
1988SupraDreams
May 19, 2007 04:43 PM
