-   Mazda BT 50 & Pickup Trucks (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/)
-   -   B2500 4x4 engagement problem' (https://www.mazdaforum.com/forum/mazda-bt-50-pickup-trucks-18/b2500-4x4-engagement-problem-25015/)
autosportdevelopment Dec 1, 2010 03:25 PM
Hi, I've recently bought a 2000 B2500 Dbl cab with 110,000 miles. very happy witth it but now I've got it in snow I've found I cant engage 4 wheel drive. If I put it in 4 low it definately is in low but the front wheels dont engage. So in 4 wheel high or low I'm still in 2wd. The RFW light doesn't come on but the 4wd light does. The fuse is ok. Any help and where to get a workshop manual would be appreciated. Thanks.
Rob.
kevinnaidoo Dec 2, 2011 02:06 PM
I got the same problem on my mazda 4x4. Some research says theres a drive chain in the transfer box that damaged. Still needs to be opened and checked though.
Kevin
autosportdevelopment Dec 3, 2011 03:50 AM
My local Mazda dealer told me to strip the free wheeling hubs. It turned out that it was a vacuum switch. Mine is Right hand drive and on the brake servo there are a couple of black plastic boxes with rubber pipework attached. One of these had snapped off. I fixed it with a couple of small pieces of aluminium tube and reconnected it. It works fine now.
Take a good look at the vacuum hoses and make sure there are no leaks as it is this that locks in the 4WD.
Hope this helps.
Rob
