b2500 2.5 diesel 2002 4x4
need help have this crewcab since new onely 60.000 miles and few months ago started to get hard to start when engine hot, start first turn cold, changed primeing pump on fuel filter plus non-return valve on fuel line now garage wants to fit engine coolant tempeture switch and if not that they say its diesel injection pump, anyone met this problem, does not seem to have the same power as it used to have but never failed to start would just turn over 8 or 10 times when hot sometimes would take second go to start, help help help regard;kieran
Originally Posted by kieran1141
(Post 114028)
Mazda 4x4
Originally Posted by B2500 Graeme
(Post 147018)
I've had same problem I've had a refurbished pump put on the after that I've had fuel line problems I replaces all fuel lines and filters it still dosent start is air getting into you fuel lines is the primer holding pressure
| All times are GMT -5. The time now is 01:04 AM. |
