91 mazda b2600i wont start
wont start will crank wont start
already checked the plugs,wires,cap, rotor,fuel pressure, every time i crank it i hear compression only on the very first stroke every other turn after the first just sounds like a starter on a motor cycle with the valve cover off i'll crank it and i see oil spit out the top off the lifters... .questions is it possable that the lifters arnt hard enuff to be able to open the valve? when I attempt to start it i put my hand over the throtle body air port & i feel the air pushing out . why is that? |
Originally Posted by Redeemer
(Post 136614)
Is the timing belt shot?
Is the crank position sensor o.k? |
Maybe this will help with troubleshooting your issue.
1991 Mazda B2600 Stumble Problem 2600i Pickup Does Respond Accelerato Been |
