91 B2200 Poor idle during warm-up
Old Feb 24, 2014 | 10:24 AM
lrw74123's Avatar
Default 91 B2200 Poor idle during warm-up
Hey Everybody,
I have a 1991 B2200 that's doing something strange I was hoping I could get some ideas on. When I start it in the morning, it starts up and as long as I don't hit the gas or anything it starts at about 2-2.5k RPMs. Over the next few minutes, if left alone, it starts to creep up slowly to over 5k+ RPMs. If I hit the gas it immediately drops the idle really low and often dies. It idles really bad (if at all) until the truck is warmed up then it runs good with no problems after fully warmed up. Anybody experience this? Any thoughts? I'm not even sure if they made any with fuel injection but my truck is Carb. Thanks in advance!
Old Feb 28, 2014 | 07:15 AM
Cusser's Avatar
You need to check
if the accelerator cable is binding or carb throttle binding, try to "release" by hand
if the throttle return spring is closing the throttle completely when you release the accelerator (a real issue if your carb has been changed to a Weber carb, as the supplied spring in the kit is WAY too weak)
make sure that the wire to the carb electric choke is plugged into the rear of the alternator; if not, the carb butterfly will remain "closed", causing a rich mixture and high idle (just happened on mine, I knocked that wire out of the alternator while replacing a belt)
56bigsky
Apr 21, 2015 07:30 AM
GearLowDriveSlow
Oct 16, 2013 06:23 PM
mcshooter79
Nov 15, 2012 10:45 PM
bhowell
Nov 28, 2010 06:08 PM
mazda_minitruck92
Nov 6, 2007 08:22 PM
