87 Mazda B2000 losing power on top end
I am new to the forum and have done some research already on my issue. I have had the truck for 2 months or so and it ran fine. About two weeks ago it started sputtering when at wide open throttle on the highway. When I took my foot off the gas slightly it smoothed out. I have replaced the fuel filter, plugs, wires and rotor in the distributor. I have checked most of the vacuum lines. What else do I need to check or replace? I read a post about the cat being clogged but I have not checked that. Any help is appreciated!
One tees in a fuel pressure gauge.
Direct the fuel delivery hose into a jar, and have a helper crank the engine. Determine volume per time.
Caution: gasoline is flammable !!! Note that a clogged fuel sock in the tank can cause decrease in fuel delivery.
And there's a good type of fuel pump, and a bad type. Both use the plastic spacer. Watch
Another question Cusser. I disconnected all three hoses going from the exhaust manifold to the air cleaner assembly. Truck ran better than ever. Miss and no power issue went away. Is the cat clogged? There is a lot of black exhaust soot on the silver part (Assuming emissions stuff) of the air cleaner assembly and the exhaust coming out of those 3 hoses actually melted the paint off of the air cleaner lid.
Also, How much of a performance improvement does the weber carb and header make? Is it a slight increase or is it like night and day? I know it's a 4 banger truck motor so it will never be fast but just with those 3 hoses off I noticed a huge improvement in acceleration and even improvment on top end.
Also, How much of a performance improvement does the weber carb and header make? Is it a slight increase or is it like night and day? I know it's a 4 banger truck motor so it will never be fast but just with those 3 hoses off I noticed a huge improvement in acceleration and even improvement on top end.
Thanks for the help. I gutted the second cat an the issue has gone away. Should I gut the first cat (right after the exhaust manifold)? This is obviously more work. Will it throw a check engine with both cats gutted?
