4x4 Problem
Old Nov 2, 2006 | 06:05 PM
junestag's Avatar
Default 4x4 Problem
Hello everyone, I've got a 2001 B4000 Pickup Truck. I don't know much about trucks or 4WD so I've been stupidly driving around in 4WD LOW this past month of winter. Today problems started: the truck is making this whirring noise (that I can only hear from inside the truck) when I accelerate especially past around 20 mph. When I take my foot off the gas the truck slows down VERY quickly almost like I'm stuck in first gear or something. I can't get the truck to leave 4WD LOW now - it won't go into 2WD or 4WD HIGH. The **** will turn but the indicator light on the dash doesn't change from 4WD LOW. Also I'm getting significant tire slippage in the back tires and the truck is jolting when I start up from a stop. I'm not even sure I can go past 30 mph right now. Anyone have any ideas what could be wrong?
Of course I'll be taking the truck in to get it looked at as soon as possible but any pointers you all could share with me would still be appreciated.
Thanks,
~ sage
Old Nov 2, 2006 | 06:42 PM
eflores's Avatar
Default RE: 4x4 Problem
sounds like you locked up your transfer case.....ouch butmy question is if youve been driving around for a month in low howd you go down the highway?
Old Nov 2, 2006 | 06:55 PM
B2900's Avatar
I would try a simple fix first.. Just change the dope in the transfer case. IF it is black you have major problems. The oil weight to replace what is in there is a 80 or 90 weight. You may be surprized this may work. As well unless you are driving on dirt of wet roads never at any time drive your truck in 4 wheel drive as your front wheels are a very slight degree slower then your rear wheels and thus you have the problem you are now having.
B2900
Old Nov 2, 2006 | 06:58 PM
B2900's Avatar
http://picasaweb.google.com/B2900302/WorkInProgress
I have been playing with this one for 7 years now...
Old Nov 2, 2006 | 07:38 PM
junestag's Avatar
Thanks for the support everyone! I got to thinking more about my problem after I wrote the post and realized that even though I thought I was in 4WD LOW all this time I wasn't - which is why it wasn't making revving noises before today and why I could drive on the road fine before today - it must have finally just switched itself into 4WD LOW today and is stuck there. Hopefully it will switch itself out of 4WD LOW but I'll still have to get the switch fixed so I can change drive whenever.
Old Nov 2, 2006 | 08:59 PM
sstlaure's Avatar
Definitely sounds like you are in 4WD low. max speed is probably around 30 mph in low
autosportdevelopment
Dec 3, 2011 03:50 AM
woodnic
Apr 21, 2010 10:28 PM
Mazdaboy2600i
Dec 5, 2009 07:51 AM
topgun
Mar 30, 2009 03:50 AM
oscar220
Mar 6, 2008 11:59 PM
