3" body lift
has anyone ever done this, what do i all need to: lengthen, move, ect. do i lose my speedo cause it doesnt look like its gonna reach another 3".
RE: 3" body lift
on what yr of truck/model??=no response.
on my 91 b2600 only thing i did was cut the fan shroud. took the mounting clips off the speedo cable and made new bumper brackets.then got a shock extender from mr gasket 3 inch and rethreaded the shifter manual tranny. |
RE: 3" body lift
AWSOME, thanks just what i needed to know its a '90 , my heater core lines look a little short how about wiring?
RE: 3" body lift
the heater hose's.
i just un clipped them from the plastic holder clamps. the wire's will extend enough. the fuel tank fill pipes will need to be extended. for that i just added pvc hose connecters1 1/2 and 1/2 inch diameter.adds close to the 3 inch lift. also my pics the truck has the 3 inch lift in the body and close to 3 inch in the suspension. on 31's with the plow. done with homemade balljoint spacers/shock brackets andtorsion bars tightened up and 2 rear leafsadded each side. photo's- https://www.mazdaforum.com/albumphot...=1&apage=2 |
RE: 3" body lift
thanks for all your info, really helpful, now i can make a list and grab all the stuff i need before hand with less down time, thanks a bunch.
RE: 3" body lift
oh can you get me a closer look at your cab mounts just so i can see how you did it.
