2600i oil pressure
Old Sep 6, 2006 | 01:19 AM
dmalensek's Avatar
Default 2600i oil pressure
I have 1989 b2600i. Once the truck runs for 1 or 2 minutes the dashboard oil light comes on. I replaced the oil pressure sending unit on the side of the block and it did not help. I am not sure what the oil pressure is suppose to be. Does anyone know? Is the easiest way to check it by putting a gauge where the sending unit is? I saw a picture that shows there is a strainer in the oil pan. Is it possible this is getting plugged? Any other ideas?
Thanks in advance
Dave
Old Sep 6, 2006 | 08:33 PM
bkey71's Avatar
Default RE: 2600i oil pressure
Oil pressure at idle is 16-30 psi and 44-58 psi at 3000 RPM. I would try a mechanical gauge where the sensor goes to verify.
I would consider dropping the pan and checking the oil pickup screen. I have had many vehicles in the past with this same problem and thats what it was. I had to remove the screen and clean it along with the pan that gets carbon build up on the bottom because it gets sucked up on the screen
Tanzanite
Jul 18, 2014 06:24 AM
Camo4x4
Oct 10, 2008 10:20 AM
gsxrsrad1000
Dec 13, 2005 04:43 PM
jeyssika
Jul 27, 2005 06:15 PM
rjdmp
Jun 10, 2005 10:01 PM
