1997 Mazda B2300 4cyl- p0340 code, misfire
I cannot figure out what the problem is on my '97 2.3L. I threw a p0340 code last week and the truck started misfiring while idling and driving (especially 2500 rpm and beyond). I have 93,000 miles on the truck and decided it was time to replace the timing belt while I replaced the camshaft positioning sensor. A local shop checked the signal from the CPS and it was good as well as the wiring. The alternator is not throwing any A/C current either (the CPS is magnetic). Does anyone know more about this problem? I have read about every thread about this. Should I replace my PCM?
Are you saying that this misfiring started after replacing the timing belt and after replacing the CPS?
How old are the spark plugs and wires? Did you check the vacuum lines? They are thin and brittle at that age. That is all I can think of now. If these pointers are fruitless you may go to fordforum.com or "the ranger station" since this Mazda is a re-badged Ranger 2.3. Good luck. |
Thanks for the reply. These issues arose before the timing belt change. I have put new plugs in the vehicle since as well as a new battery (mine died). As far as I can tell the vacuum lines are fine. I am about to try a reman PCM. Is it possible the ICM and the crankshaft sensor are not telling the plugs to fire causing a misfire? Can the PCM screw up the codes?
Originally Posted by truckproblems
(Post 145535)
(Post 145540)
The PCM does help control voltage. Low voltage while starting is not a good thing, it might not start and misfire. Could also be a bad ignition coil, wire |
Yep. I tested the alternator and it is giving the correct voltage output. I'm going to check the coils and ICM before I put in a new PCM.
It does not have a misfire upon starting. The PCM somehow looses the signal from the camshaft positioning sensor, especially past 2500 rpm. |
Gonna give you my favorite Misfire List:
Missfires Can Be Caused By a Million and One Things, Vac Leaks Wiring Issues Spark Plugs(Even Fresh Spark Plugs That Are Crappy Quality.... E3 And Such) Ignition Coils Alternators (Search EMI) MAFS Injectors Injector O-Rings Intake Gaskets TB Gaskets PCV Hoses PCV’s Malfunctioning EGR Malfunctioning CAS O2 Sensors Aftermarket Intakes Intake Hoses Vac Lines Timing Chains Timing Chain Tensioner Broken Cam Gears Malfunctioning Cam Sensors Incorrect Crank Gears(The I4 Has Like 40 Different Configurations For Whatever Reason) Incorrect PCM Flash Issues Within The PCM PCM Wiring Bad Diaphram Within The FPR Issues Within The Fuel Pump Dirty Fuel Filter Dirty Fuel Lines Pre-Cats/Poor Exhaust Flow If the above gaskets/seals have not been changed, change them. Clean your MAF sensor, throttle body. Change your PCV valve and probably that short hose as well. Inspect the intake accordian tube for cracks. Inspect for vaccuum leaks. Put in a good Fuel system cleaner: Red Line Synthetic Oil - Gasoline Fuel Additives - SI-1 Complete Fuel System Cleaner Inspect wires. Re-set ECU after doing above. I had a misfire on 1 specific cylinder with only 30,000 km. After changing the ignition coil, spark plugs (all), fuel injector for that cylinder, they changed the fuel tank and the fuel pump. (all under warranty) Still got a misfire! They changed the pre-cat on 1 side. It was the piss poor exhaust design! Poor exhaust flow. I immediately changed the exhaust design after the pre-cats. Not under warranty: I changed the main cat and the pipes coming out of the pre-cats. No more issues! For more in depth, read: https://www.mazdaforum.com/forum/maz...-design-28940/ |
This is really a great list to work from. Go from cheap fixes to the more expensive one. Test, test , test, clean and re-use. Do not throw parts at it.
Oh yeah, my misfire only happened at hi revs at around 5000 rpm while i was flooring it, getting on the highway in 2nd or 3rd gear!
Good luck. |
