Diamondx2 |
04-06-2009 03:13 PM |
1994 B4000 temperature gauge fluxuation-engine has 85,000 miles
1994 B4000 temperature gauge fluctuation at idle and on road-has a brand new radiator and cap also new thermostat. Gauge fluctuation off idle in park, and when at driving speed. What's the cause? The clutch fan was checked and it was tight on the shaft w/no front to back 'wiggle'. At idle the gauge stays in one place. If the engine is revved the gauge climbs and when rev goes back to idle the gauge returns to its lowest reading. On the road the gauge seems to 'cycle' from its lowest reading (just below 1/2 when driven 20 miles or more), to about 3/4 'hot'. Before the stat was replaced there was no cab heat at all; since the stat was replaced cab heat is comfortable even at 35F outside air temp. The fuel gauge does not have any fluctuations at all.
