| oldeng |
Apr 28, 2009 11:09 AM |
Yes internal leaking IS possible (it's also called bypassing). The piston cups are shaped so they taper outward slightly, and the tips have an internal chamfer. This is so that the moment the slightest pressure is applied, the cups flare outward giving a firm seal capable of resisting the peak pressure which follows. Being thinner, the tips of the cups are the first to wear. This shows up as residue in the clutch fluid which typically is darkened and can contain tiny particles of detached skirt. These particles can migrate anywhere in the system and if they lodge between the piston cup and cylinder wall, cause the piston(s) to bypass fluid. Similarly, if you have rusting of the hydraulic lines, fine rust particles can have the identical result.
Your comment about "all kinds of interesting things came out" suggests you've reached clutch hydraulics overhaul time. A good test is (a) measure your clutch free travel and compare to manufacturer's spec. (b) Depress the clutch very, very slowly and note how far it has to go before it "bites", and if the "bite" is solid.
If one cylinder has gone, please replace/ rebuild BOTH, and clean/ replace the lines and do the reservoir thoroughly too. Make sure your working conditions are scrupulously clean and use only clean new lint-free wipes. Bleed the system really well too, and use only brand new brake fluid fresh from an unopened container. Brake fluid absorbs water beautifully, and an old partially used can of the stuff will be contaminated with water, and if in a tin rather than a plastic container, will contain rust as well.
When you've finished, find a plastic container just big enough to hold your fluid, having a good seal, and keep your extra brake fluid in it (discard your bled fluid). That way you can keep fluid indefinitely without risk of water or rust contamination.
