1990 B2600i 4x4 issue
Old Oct 24, 2020 | 09:41 AM
Josephlj945's Avatar
Default 1990 B2600i 4x4 issue
I have a 1990 B2600i 4x4 with a 5sp manual, I’ve had it for about 2 months. I thought that 4x4 was working because when I put it in 4Lo it seemed like it was crawling like it should.
Well last night we got a snow storm, and I got stuck and 4x4 was absolutely NOT working, but in 4L the gear range still changed but only the rear tires were spinning.
Later that night I started messing with it more, I pressed the RFW button probably 50 times, and slammed it into 4L and the lock light came on, but no 4x4 light. 4x4 does seem to be working now, I couldn’t get the rear end to spin like the previous night and I drove around in the snow for about 10min, however still no 4x4 light.
I’m afraid to unlock the hubs now that I got them locked and 4x4 supposedly engaged.
I’m not really sure what to do, I don’t have the mechanical expertise for that sort of stuff. It pretty much ends at changing spark plugs and oil.
I bought this for my 60mile commute to work in north Idaho over 4th of july pass. 4x4 is an absolute necessity for me.
Old Oct 24, 2020 | 02:14 PM
Cusser's Avatar
I have a dumb response, but you said the truck is new-to-you. Go underneath and make sure that the drive shaft for the front wheels has not been removed.
Old Oct 24, 2020 | 05:18 PM
I had the whole front end (really the entire suspension) gone through at a shop. I had a new rear end installed, and the wheel bearings in the front.
I'm thinking it is something electrical, or vacuum related to the RFW?
Old Oct 25, 2020 | 05:50 AM
Are the RFW hubs vacuum operated? Common problem for vacuum leaks & faulty solenoids.
Old Oct 25, 2020 | 11:20 AM
Yes they’re apparently vacuum operated. I will have to check for leaks when I finally get to my days off (working a 4 day 12 hour week this week).
I like the idea of the automatic hubs but I feel like a manual hub setup would’ve been more reliable...
RevGrmRefer
Jun 23, 2020 02:33 PM
dngonzales
Mar 17, 2019 03:45 PM
lipo35
Sep 27, 2008 09:23 PM
lipo35
Feb 24, 2007 04:31 PM
Btruckr
Jun 10, 2005 03:43 PM
