1987 B2600 Auto Tranny shifting issues
I recently obtained a nice 87 b2600 with an auto tranny. It runs ok but when you take off, the tranny does not seem to shift? it just runs like it is in 1st or 2nd gear. if you take it to about 25mph and then let off the throttle just a hair it will shift and be good to go, untill you stop? I replaced the vacuum modulator and it seemed to help a bit but still not right?? any ideas.
thanks
thanks
mileage is 160k, fluid looks and smells good. It has a new head and new carb with in the last 6 months. This truck was owned by a grandmother and was taken care of. The part i dont understand is that it will shift, when you lift the gas pedal, it does not shift hard or anything. When i replaced the shift modulator on the tranny it seemed to help quite a bit.????
Yes it is separate, the modulator uses vacuum to sense engine load, the kickdown rod/cable uses throttle position to sense driver input. It is also possible there is a vacuum leak somewhere that is making the modulator THINK that there is less manifold vacuum (therefor higher engine load) than there is.
It's worth a try, but I am not totally convinced. The tranny should shift automatically without it.
You never know. It's worth a try!
Good Luck.
However, work on engine may have issues with linkage.
ok so i found the kick down switch, i backed it off and it seems to be doing 100% better, still not liking the shifting? its smooth just not at the right rpms. BUT way better than before. It seemed like the pedal was hitting the kickdown switch way to soon. Thanks for all the help guys!!!!!
