1987 B2200 Gas Guage!! Not the sending unit
Old Nov 1, 2012 | 08:41 PM
jbmcclint's Avatar
Exclamation 1987 B2200 Gas Guage!! Not the sending unit
Does anyone have a diagram for the dash cluster ,gas guage not working I have never seen it off Empty put a new sending unit on and still dont work check the resistance on old unit and it is fine. connections are good as well, and has a voltage at plug as well witch moves with the float as it goes up and down. Has anyone ever just has a bad guage?
Old Nov 2, 2012 | 12:45 AM
MazdaTirol's Avatar
It is possible, I had my printed circuit on my old mustang burn through once, that was a PITA to fix. Any other issues with the instrument cluster? Pop it out, check the connections and the printed circuit for damage, if no damage check the resistance at the connector for the fuel gauge to see if there is a complete connection from the dash back.
Old Nov 2, 2012 | 09:24 PM
Pantharen's Avatar
it might not be the sending unit. Check to see if the wire from the float is actually touching, they tend to bend, and lift off the board, and no longer make a connection..
Hell I never drive by anything other then mileage anyways... gas gauges are misleading..
camaroman
Dec 1, 2014 01:39 PM
Sal1992
Mar 18, 2012 12:27 AM
lil' lucifer
Apr 6, 2009 11:53 AM
cep623
Mar 3, 2008 08:02 PM
ITR000
Dec 13, 2006 05:49 PM
