12-valve cylinder swap?
Old Jan 23, 2021 | 02:29 AM
LN323's Avatar
Default 12-valve cylinder swap?
Just trying to confirm whether or not the 12-valve head works on the B2200 2.2L motor.
I thought I was in touch with someone that said it does. Anybody here try it? What parts do I need to make sure I grab off a donor in the junkyard? Do all the oil ports and water ports line up?
Old Jan 23, 2021 | 06:09 PM
MeB2000's Avatar
Yes it will bolt up, but, the distributor would be located at the rear of the head and the firewall is in the way. That said, if you can locate a front housing for an Mazda Bongo (imported from Australia?) then that locates the dist. at the front of the head......from what I understand this is possible, although I have never done it!
Old Aug 12, 2021 | 08:01 AM
KevinBruyne's Avatar
These parts are surely available at junkyard because junk car removal companies separate those parts and place it aside in the junkyard.
mazda2nvs
Feb 17, 2012 05:51 PM
goober86442
Jan 26, 2009 12:09 PM
turbo22
Dec 18, 2008 10:55 PM
dadslx
Feb 23, 2008 11:07 AM
Slo
Jun 6, 2006 06:29 AM
