temp sensor
Old 01-24-2010, 01:54 PM
Times's Avatar
Default temp sensor
just bought a 94 323, 1.6. Engine stalls when warmed up. Bought a haynes maual, check engine light goes off and on. Pulled code 09, manual says temp sensor. Found the one on thermostat housing which controls the fans, found the one on block which goes to guage, manual say the other is next to the distributor, not there. Did break wiring harness to the sensor on the thermostat housing changing thermostat, but the code was there before i did that, any ideas? thanks
Old 02-07-2010, 07:35 AM
grey's Avatar
it is there somewhere....
look all around the the head maybe under the throttle body
look down on the bottom of the radiator.
when you find it just unplug it and see if the car stays running. this test will tell you something
sorry I could not locate it for you (but this will bump you back up)
also, try "autozone .com" for free repair guides....might have the info.
Old 02-08-2010, 06:30 AM
Times's Avatar
Default Found it
I did find it, on top of intake between 2 injectors, just didn't realize that was it, thought it was injector wiring. It did fix it.
ozmazda1993
12-12-2011 12:17 PM
04Mazda3Sport
10-08-2008 04:16 PM
oneshot onekill
04-11-2008 03:03 PM
edsmith01
07-25-2007 03:10 AM
eric777
07-15-2007 08:06 AM
Quick Reply: temp sensor
