Brake Fluid change
No special equipment required.
Empty the brake fluid reservoir as much as you can, add fresh fluid, bleed from the wheel furthest away from the master cylinder & work you way around to the nearest wheel last. I always use about 700-800 mls when doing my own cars.
Thank you for that information. I asked because my son has a Ford Fiesta and the proper way to purge the ABS on that is using Ford's IDS system, otherwise there are channels and a small reservoir that hold brake fluid under normal bleeding.
I will now get the job done.
Cheers
Cheers
