Signal Light
Hi All,
I own a 1993 mazda 626 and this forum has been very helpful with the few problems I've had. Today, I tried to replace the front right signal bulb and just could not figure out how to open the casing. Does anyone know how to open headlight casing for this type of car? Is this a do yourself job? Are there any bolts I should unscrew to access the old bulb? Thanks for your help again. |
RE: Signal Light
You just need to rotate the socket for the turn signal bulb counterclockwire about 45 degress and should pull right out from the backside of the headlamp assembly.
RE: Signal Light
Thanks for the reply. Babyhuey.
Where exactly is this socket for the turn light located? The only sockets which come off are for the headlights. Thanks for all your help and advise. |
