p0171 bank 1 running lean
My 1998 mazda 626 es 2.5L engine is running rough at idle and acceleration. I just replaced my valve cover gaskets and checked for vacuum leaks. I did run across a blue/yellow strip wire that looks to connect to the engine somewhere and leads back to the PRC solenoid. I have looked all over the Web and repair manual with no answer to where it plugs into on the engine. It looks as though it goes onto a post of sorts as its a round plug for a single wire. Any suggestions?
The blue/yellow wire goes to the PRC solenoid (pressure control solenoid valve) Fuel pressure regulator solenoid. According to the wiring diagram. There should be a vacuum hose coming from the fuel pressure regulator to the PRC and another vacuum hose going straight to intake vacuum. It should not set a code for one bank unless there is a vacuum leak on bank 1 intake runner.
chitowntommy
Jan 13, 2008 10:21 PM
