New member, need help with 02 626 idle problem!!
Old Apr 9, 2007 | 11:41 AM
tonyben's Avatar
Default New member, need help with 02 626 idle problem!!
Hello all. I am the original owner of a 2002 626 with the 2.5l V6.
For over a year now, I have a problem with the idle when the vent/AC or heater is turned on. Once the cooling fan kicks in, my rpm's jump by about 300 to 500 RPM's but only when in gear. When the shifter is in park, the idle only fluctuates by maybe 20 rpm. When the car is on the freeway, I can feel the RPM's kick up by about 20 rpm. When in second or third gear, doing under 45 MPH, the rpm's kick up about 200 rpm's
I have installed new spark plugs, cleaned the MAF sensor out and replaced the plug wires. The alternator is only a couple of years old. I tried un-plugging the alternator and the fans but when the relay kicks on, the problem still persists.
Any input on the problem would be greatly appreciated or even if someone knows where I can find a good online source for information, that would be very helpful too.
Thanks, Tony.
Old Apr 14, 2007 | 11:15 PM
adams9663's Avatar
Default RE: New member, need help with 02 626 idle problem!!
if it is an automatic the transmission might be slipping at the shift points you might need to have the transission filter replaced.
Henrylee
Feb 2, 2014 01:34 PM
Vertz24
Oct 22, 2008 12:13 PM
gregmsr
Sep 6, 2007 09:56 PM
xtrigger
Aug 10, 2006 07:02 PM
bomb1977
Mar 2, 2006 02:33 PM
