-   Mazda 323,Mazda 626 & Mazda 929 (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/)
-   -   Mazda 323 headlight problem (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/mazda-323-headlight-problem-42826/)
Norman88 Sep 20, 2019 06:12 AM
https://cimg7.ibsrv.net/gimg/www.maz...f436f6b645.jpg
The lower is the old, the upper is the new fuse I bought
I just bought a 1995 Mazda 323 sedan a good month ago. The entire headlights just doesn't works, so I suspected de fuse gone out. I changed it, but still noting. I checked the bulbs, vut they seems ok.
Anyone has any idea guys?
grim_reaper Sep 20, 2019 09:42 PM
Are you getting power & earth at the headlight bulb connector?
Is the headlight relay clicking when the lights are turned on? Are you getting power, earth & trigger feed to the headlamp relay/s?
Norman88 Sep 25, 2019 12:49 AM
The relay clicks when I turn on the position lamp. I guess it means its ok, but is that same raley works the other lamps too?
grim_reaper Sep 27, 2019 05:01 AM
Have you checked for power & earth?
Norman88 Sep 27, 2019 12:22 PM
Yes, they seem ok. I guess the last chance must be a cable problem
Kami Nov 1, 2019 02:03 AM
Check you fuses from inside, not outside.
