-   Mazda 323,Mazda 626 & Mazda 929 (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/)
-   -   keyless remotes (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/keyless-remotes-251/)
asp9106 Jan 26, 2005 01:47 PM
keyless remotes
I have a 2000 Mazda 626 ES and I lost one of my keyless remotes I recently purchased a new one but I do not know how to program it. Can anyone help me with this ?
Thanks
Alan
Hamden, CT
MAZDASERVICE Feb 2, 2005 04:06 PM
RE: keyless remotes
RETURN TO THE DEALER WITH ALL REMOTES AND KEYS-THEY WILL REPROGRAM THEM-THE COST TO DO SO SHOULD RANGE ANYWHERE FROM 25.00 TO 42.50
98Millenia Nov 26, 2005 02:49 AM
RE: keyless remotes
I was looking for replacement keyless entry remotes not too long ago and I found a site that had them really cheap for my Millenia and Miata.
I had them delivered in less than a week and the programming instructions only took maybe 10 seconds?
Anyways, here's a link to the site:
Https://www.ThePartsYouNeed.com
Just click the Mazda category, or type your model in their search box.
babyhuey Nov 26, 2005 11:56 PM
RE: keyless remotes
1. All doors closed, key on.
2. Remove key
3. Open drivers door and leave open. 4. Insert key into ignition and turn from on to lock three times then remove key.
5. Close and then open drivers door three times, leaving open on third.
6. Listen for a single tone chime. You are now in program mode.
7. Push any button on transmitter #1 two times. Should hear same single tone. That transmitter is programmed.
8. If have only that ONE transmitter then repeat step 7 two more times with transmitter #1. Programming complete. Go to step 11.
9. If have TWO transmitters then push any button on transmitter #2 two times. Should hear same single tone. Transmitter is
programmed. Push any button on same transmitter two more times. Same single tone. Programming complete. Go to step 11.
10. If have THREE transmitters then push any button on transmitter #3 two times. Should hear same single tone. Programming
complete.
11. Two tones should sound at the end of programming to indicate procedure done correctly and exiting programming mode.
