-   Mazda 323,Mazda 626 & Mazda 929 (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/)
-   -   Interior Fan problem (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/interior-fan-problem-20038/)
k20dec Sep 3, 2009 08:30 PM
Hi all,i'm new to the whole Mazda scene and very impressed so far.Just bought a '01 323F 1.6 .The interior fan only works on level 4,what do i need to fix it?the car is fitted with a/c but this still only works on level 4.Thanks for your help in advance,cheers guys.
oldeng Sep 4, 2009 01:20 PM
If you do a search of this forum with A/C heater fan fan speed etc. you'll find stuff where owners ave had similar problems, with opinions about equally divided between the fan switch and the fan motor resistor bank being the culprit. Without stripping things down and doing the electrical measurements, you just can't make the call.
Since neither part is very expensive, both equally failure prone at your vintage, and both demand stripping out some trim in the same general area, in your situation I'd be tempted to replace both and rest content knowing that you will not have a recurrence of either a switch or a resistor bank problem for the likely life of the car.
k20dec Sep 5, 2009 07:44 AM
Thanks for your help Oldeng.Much appreciated.
