If I wanted to put some new speakers in?
What would I need to do about the wiring? I mean would I have to get a bigger size? How do you run hard is it to run new speaker wires threw my little 323?
Any one done this befor? Also if I get a new radio/head unit how hard are those to install? I mean would it be easier to just take it some where and have it done? |
RE: If I wanted to put some new speakers in?
New wiring should not be needed unless you are going to add amps or put in a high output stereo. Factory wiring is small gauge but should be ok for most additions. Installing your own stereo not difficult either. Instructions are usually fairly clear and wires marked well as to what they should be connected to.
Lol ok so pretty easy then.
Thanks |
Just get the correct size replacement speakers and it is easy. What I have done to my cars is cut the factory connector end off and splice the new end that comes with the new speakers. You can either solder and shrink wrap or use crimp connectors.
And we will all give the wires identification that will help in the install.
ok thanks
