Is hum/buzz normal?
Old 10-13-2010, 01:12 AM
ActionClaw's Avatar
Default Is hum/buzz normal?
I'm having a little difficulty resurrecting a 1992 Mazda 626 after it's been sitting for a few years (see additional details here)
There's a chance the problem may have to do with the fuel injectors —or something that controls them. Coincidentally, I can hear a slight clickity buzz/humm (like that from a transformer, electromagnet, relay or similar) that sounds as though it's coming from directly under the printed "2.2" on the air intake manifold. I'd like to know whether or not this is normal.
Do any of you with a similar but functional car, with the key in the ON position, engine not running, hear something similar?
Thank you
Old 10-14-2010, 02:27 PM
Ferret626's Avatar
Actually I have recently disassembled most of the engine compartment of that car (1992 Mazda 626 2.0). The first time I inserted the ignition key and turned into "on" position I carefully checked that fan, lights and electric windows worked.
Before (trying) to start the car the first time - I noticed a lot of clicking noises from the engine area. I thought it was something with the fuel pump or similar which was building up pressure again, but I never tried to localize the sound.
As I normally have the hood closed (and it has a good sound isolation) I have not thought about that sound before in "normal" conditions. I will start and drive the car some before Sunday evening - if still interesting I could listen for those sounds again.
BTW: Adding a quick link how my engine looked like during disassembly. http://i6.tagstat.com/image05/c/223f/0007002328_.jpg
(just battling the car rust at the moment...)
Old 10-16-2010, 02:25 PM
Ferret626's Avatar
Default One "click"
Well, I turned the ignition key two notches to the right this morning. I heard one "click" from under the hood but nothing more (apart from the fans starting inside the car). As mentioned earlier I heard multiple clicks just after the car was assembled.
Drove it successfully to nearest gas station for some fuel and car cleaning (before trying to fix the rusty spots).
KMiddleton
06-02-2018 10:41 AM
andcam
07-01-2013 01:50 PM
Simon321456
02-28-2013 04:15 PM
Aubrey
03-21-2008 07:45 PM
bitnick07
04-12-2005 12:09 AM
Quick Reply: Is hum/buzz normal?
