Horn is silent - '84 929 HB coupe
Old May 23, 2020 | 09:29 AM
Simon75's Avatar
Unhappy Horn is silent - '84 929 HB coupe
Hi everyone, my horn stopped working a month ago when I took apart the steering wheel (I broken clip was grinding against plastic making it very annoying to steer). I just changed the steering wheel yesterday, thinking it would solve my problem (I installed a steering wheel from the previous generation 929, looks way better!). As it's plug and play installation I don't think the problem comes from the steering wheel, especially that It stopped working a few months already. I checked the fuse (in the manual it says it's the N.1, for break lights & horn) and it's all good, now I'm thinking that I might have short circuited something when I took the steering wheel apart. When I try to honk no sound comes at all...
Does anyone know if there's a relay for the horn in this car? Where would it be located? Could the problem come from the horn itself, even thought very unlikely?
Any help would be appreciated, so I can honk my beautiful new steering wheel !
Old May 25, 2020 | 09:11 AM
Pilot65's Avatar
Hi, it sounds like you may have disturbed the horn wiper contact or slipring that transfers the signal from the two switches and down the column.
Seem to remember there was a couple of horn related spade connectors under the steering wheel.
I also believe there is a horn relay somewhere in the engine bay...
Attached the whole manual of wiring diagrams for this car in case you have to start digging.
PS: Seems upload the 65MB manual is not accepted for unknown reasons. If you really need it we'll find a way
Old May 25, 2020 | 11:11 AM
Simon75's Avatar
Hey Pilot65 ! Could you email me the wiring diagram? Would help quite a lot ! For now I will unscrew the plastic parts under the column to check the wiring, but I still think there's a great chance it's the relay that causes my problem, because the fuses in the cabin & under the hood are all good. Here is my email (alagnous@ gmail. com)
Takk !
Old Jun 1, 2020 | 12:34 PM
Pilot65's Avatar
These are much to large for email. Sent you a private mail with download links.
Old Jun 2, 2020 | 02:00 AM
Pilot65's Avatar
Simon, The manuals are too large for email. I sent download instructions to your email.
You may also get it here (I believe links expires in 7 days so grab'em while you can):
1986 Mazda 929 2.0i HB Wiring diagram:
<https://easyupload.io/t66p3b>
1986 Mazda 929 2.0i HB Mechanical Workshop Manual:
<https://easyupload.io/9tpfsc>
Old Jun 7, 2020 | 07:27 AM
Simon75's Avatar
Hey now I've just cleaned the back of the steering wheel, the metal part that touch the spring, and the only difference Is that I now have a clicking sound coming from under the dash. I've heard it from close and it seems that it comes from the CPU and not the fuse box (I'm 99% sure). Since I cannot pull and replace the relay like on some other cars because it seems located within the cpu what should I try next? Bad ground connection? Horn died? I'm really confused it worked just fine when I bought the car...
trickrider
Sep 24, 2015 07:57 PM
lorigirl
Dec 3, 2007 10:04 PM
rubenmazda1994
Nov 29, 2007 08:18 PM
98mazda
Jun 23, 2006 02:48 AM
